9/30/2010 11:14 AM | |
Posts: 29 Rating:
Thanks a lot... Can you tell me the serial of the cable ?? or where can I find a more info about this cable. |
9/30/2010 1:47 PM | |
Joined: 3/21/2006 Last visit: 2/10/2025 Posts: 10239 Rating:
Hello, Just clarify a little bit more Sandman' advice. You can't to use PC/MPI-Adapter and USB/MPI-Adapter for transfer. For using Profibus or MPI you will need additional settings in PC. For this reason, I recommend you to use simple cross ethernet cable to download the project. About using ethernet cable look at http://support.automation.siemens.com/WW/view/en/23335365 Best regards, Hristo Mihalev |
10/4/2010 7:14 AM | |
Hello, Look there - http://support.automation.siemens.com/WW/view/en/19109408 After we could continue with discussion here. Best regards, Hristo Mihalev |
