12/8/2008 12:01 PM | |
Joined: 9/24/2008 Last visit: 4/10/2025 Posts: 30 Rating:
Assuming that you have SCOUT and firmware v4.1, you can use the PATH functionality. Create a path objectcontaining your 2 axes. You can then traverse your geometrical shapes by positioning the path object to 2D coordinates. For more information you should refer to the Path Interpolation documentation. https://support.automation.siemens.com/WW/llisapi.dll/csfetch/32817421/Path_interpolation_technology_object_en-US.pdf Nick |
12/8/2008 1:10 PM | |
Posts: 31 Rating:
The problem is that i have SCOUT V3.2.1, and there is no path interpolation commands there ( |
