12/1/2022 9:25 PM | |
Joined: 11/24/2022 Last visit: 7/8/2023 Posts: 6 Rating:
Hi all, I'm truing to do the same, where I want to save my variable after a reboot or power loss. However I cannot find the link between the LWE and the logo plc. In this example LWE is bound to VW02 and VW03, and the math function are B003 and B004. Can you please explain how I can link an Analog slider to a math function? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 12/02/2022 04:47:06New subject after splitting |
12/2/2022 3:15 AM | |
Joined: 12/18/2014 Last visit: 12/3/2023 Posts: 31538 Rating:
Your description may be understandable for you, for me only so far that I know what you want to do. I cannot give you an exact solution without knowing your program and your LWE project. Blanket question, blanket answer. Edit: The addressing of the LOGO! byte oriented. A word has two bytes. See attached file. AttachmentLOGO! Bit, Byte, Word and DWord.pdf (256 Downloads) |
12/2/2022 6:22 AM | |
12/2/2022 8:04 PM | |
Thank you. that did the trick. |
12/2/2022 8:07 PM | |
That's what I wrote in my first answer ... |
