9/18/2017 2:10 PM | |
Posts: 5 Rating:
hello i have an old s5 project and a .396 file on it how can i read the .396 file i dont know how to find com396 package please help regards ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 9/19/2017 9:48:41 AMNew subject after splitting |
9/19/2017 9:21 PM | |
Posts: 92 Rating:
Hi you may need to explain more, especially about the type of your controller and what blocks you need to explore, I myself can not get your mean. Regards |
9/23/2017 1:01 PM | |
Posts: 92 Rating:
Is the Files format like this: ****ST.S5D, *****Z0.SEQ, ****Z0.INI, ****PX.INI Or what kind of format do they got? Also, to read/write a plc " block" you need to make a project in Step5 and import your backup file (the PLC files format is: ******ST.S5D), then you'll be able to rd/wrt blocks entity. Look at the attached pdf, hope to be useful Goodluck With That Kind Regards AttachmentOP396EN.PDF (77 Downloads) |
