11/23/2017 4:38 AM | |
Joined: 8/9/2011 Last visit: 11/1/2023 Posts: 324 Rating:
Hi Is it possible to have the below configurations 1) Step 7 Professional V13 SP1 (PLC) with Wincc Professional V14 SP1 (RT) 2) Step 7 Professional V14 SP1 (PLC) with Wincc Professional V13 SP1 (RT) I have my runtime PCs running with RT Advanced programmed in Wincc Professional V13 SP1 platform and controller in Step 7 Professional V13 SP1 But I have purchased Step 7 Proffessional V14 SP1 alomg with RT Advanced V14 Sp1. My issue is 3 PCs running on V13 advanced RT controller with S7 V13 SP1 How can I run all 3 running V13 advanced RT + V14 advanced RT with common controller (Either V13 SP1 proff Or V14 SP1 proff ) ! With Regards ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 11/23/2017 12:32:38 PMNew subject after splitting "Any intelligent fool can make things bigger, more complex. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction.":):) |
11/23/2017 7:25 AM | |
DearChristophD , I am looking for below quoted. Pls suggest me a solution
Last edited by: GaJEnDrA D S at: 11/23/2017 7:26:07 AMLast edited by: GaJEnDrA D S at: 11/23/2017 7:46:27 AM"Any intelligent fool can make things bigger, more complex. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction.":):) |
11/28/2017 4:32 PM | |
Posts: 648 Rating:
Hey GaJEnDrA D, you can use the "Compatibility Tool for Automation and Drive Technology". https://support.industry.siemens.com/cs/ww/en/view/64847781 It shows all compatibilities and it's for free - developed by Siemens. With best regards rh1990 |
