2/20/2020 7:54 AM | |
Posts: 1 Rating:
Hi I want add HMI, MP 277 8" Touch to Tia portal , someone can help me ? thanks |
2/20/2020 8:54 AM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello kamyar here is the official Information source: https://support.industry.siemens.com/cs/de/en/view/109753803 -> --------------------- Changed device support The following HMI devices are no longer supported as of TIA Portal V15:
Furthermore, HMI devices (Basic Panels, Comfort Panels and Mobile Panels) that are configured with device version V11.x are no longer supported as of TIA Portal V15. To continue using projects that contain HMI devices with V11.x in TIA Portal V15, change the device version of the respective device to at least V12.x before opening the project. ---------------------- Bye Murof |
Last edited by: Murof at: 02/20/2020 08:54:57If this Information really helps, you could use the Rate function |
