1/14/2018 1:31 PM | |
Posts: 3 Rating:
How do you configure pc station CP 5613 as DP master on an IM 308-C as DP slave on? |
1/14/2018 4:11 PM | |
Joined: 9/27/2006 Last visit: 5/29/2023 Posts: 12024 Rating:
Hello Ali; What exactly are you planning to do? If you plan to create a stand-alone DP-master interface for your CP 5613, this document will provide guidance, documentation and programming tips: https://support.industry.siemens.com/cs/fr/en/view/1653531 If you have something else in mind, please explain in more details. Hope this helps, Daniel Chartier |
1/23/2018 9:18 AM | |
Posts: 3 Rating:
Hello Daniel Thank you very much for your attention. I have a PC with CP5613 in one side and on the other side there is a S5 cpu (S5-155U/H/CPU 948) with IM-308C (6ES5 308-3UC11). The goal is to make connection to IM-308C with CP5613 through a PROFIBUS DP connection and read/write data on Wincc HMI(V7.2) pages. I set the memory card on IM-308C and station configuration on PC with accordance to attached file. Please help me to make this connection. Thank you in advance for your cooperation. Best regards Attachment1.pdf (36 Downloads) |
