4/9/2020 8:23 PM | |
Posts: 1 Rating:
How does 3UN2100-0AF7 work,. Is it based on temperature. We did simulate to remove from Motor for NDE Bearing temperature & connected an instrument to simulate temperature rise by changing resistance. However this test did not work out. The Thermistor protection relay operates once the loop is disconnected. i.e once the device or Thermistor sensor is disconnected the device operates. Please let me know whether this Testing is OK. As per manula first temperature will go down & thereafter increase. At some point will it give open circuit. Thanks ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 04/11/2020 09:35:37New subject after splitting |
