3/25/2024 7:37 AM | |
Joined: 2/12/2013 Last visit: 2/8/2025 Posts: 10 Rating:
Hello Celio, I have tested your script in WinCC V 7.5 but it won not work. Can you guide how select next IO filed when enter key is pressed or after barcode scan HMIRuntime.Screens("Temp Oven 01").ScreenItems("I/O Field31").Activate Error Got in Diagnostic Function. Error : get_Item:The parameter is incorrect. ============HMIScreens============ ============HMIScreens============ Application : Picture : Temp Oven 01.pdl_Events Function : Sub IX002FOX0020Field33_OnObjectChanged(ByVal Item) Line : 2 Error : get_Item:The parameter is incorrect. With Regards, Yogesh Patil ------------------------------------------------------------------------------------------ |
Last edited by: Yogesh Patil at: 03/25/2024 07:38:52Last edited by: Jen_Moderator at: 03/27/2024 13:29:54New subject after splitting. Quote inserted. |
4/29/2024 4:34 AM | |
Dear Sir, Please, find attached .pdl file. which contain code. Please, check what's wrong in it. AttachmentIO_Filed_Activate_Trial.zip (392 Downloads) |
