2/13/2014 4:03 AM | |
Posts: 11 Rating:
HI ALL, I have a problem, I want to connect 4 PLC to one HMI-SCADA runtime, can you help me, and how to configure it?
2/13/2014 8:48 AM | |
Posts: 1299 Rating:
Hello, which runtime system do you use? Here is the chapter in manual about communication with s7-1200 for runtime professional. See also the hints about communication here. K!ke |
2/13/2014 11:21 AM | |
Joined: 9/14/2012 Last visit: 1/16/2025 Posts: 91 Rating:
Add 4 plc in Your Project, then Pc system, Wincc runtime,IE Genral.Add the connection (or) browse the tags from Plcs.i have attached sample project & picture for your info.
Attachmentsample_wincc.zip (293 Downloads) |
Last edited by: vijay.v at: 2/13/2014 11:22 AMcheck this thread also /tf/WW/en/Posts/103201#top Regards, |
2/13/2014 11:30 AM | |
Hi, Check this attachment also Attachmentconnection status.zip (251 Downloads) |
Regards, |
2/14/2014 3:50 AM | |
Posts: 11 Rating:
Thank you so much. |
2/14/2014 4:09 AM | |
Posts: 11 Rating:
dearvijay.v, when I load your project, I can't open it. |
2/14/2014 4:45 AM | |
Posts: 11 Rating:
Hello Vijay.v, thanks you so much because I'm beginner you can record video then share with me. thank you so much. |
2/17/2014 8:13 AM | |
Posts: 1299 Rating:
Hello, do you have anyprecise questions regarding this topic? did you check the links I gave you and the pictures from vijay.v? K!ke |
12/8/2014 12:51 PM | |
Joined: 9/1/2005 Last visit: 1/17/2025 Posts: 4114 Rating:
new question published by SIS ANis split to a seperate thread with the subject How many S7 can connect to PC via IE ethernet?. Best regards CS Moderator |
