2/25/2014 2:23 AM | |
Joined: 3/8/2011 Last visit: 5/17/2023 Posts: 262 Rating:
Hello, The first thing is you can calculate how much space does web server take by using your card. If you want you just create a dummy project and check how much space does it takes. Attached you will find list of MMC card. Rite now check how much MB is used and try to figure out minimum how much memory is occupied for Web server after activating. AttachmentS7-300_Memorycard_en.pdf (33 Downloads) |
If this post helped you, you may use the Rate-button |
