3/6/2012 5:24 AM | |
Joined: 4/23/2010 Last visit: 12/9/2023 Posts: 8071 Rating:
Hello Pee El Sea, Thanks for your reply. What I would like to know is with the connected measuring system & controller system how much minimum motionsystem can read & control. Please find attached here with example ofspindle where in minimum degree system can measured is calculated. Same like I would like to know about linear axis. But no where I could find the same. Hope my query is clear. Regards, DEEP. AttachmentMeasuring systems of spindle.pdf (210 Downloads) |
3/7/2012 1:14 PM | |
Hello Pee El Sea, You explained a lot & not bit. I have some queries about the out put sine wave & its measurement. Please find attached here with the pdf documents in which I have tried to mention my queries. Kindly reply. Also it will be great help to me if you could kindly explaine me as how to calculate the best resolution we can get. With regards, DEEP. AttachmentMinimum position accuracy.pdf (202 Downloads) |
3/9/2012 10:00 AM | |
Posts: 664 Rating:
Please Give us the reply,Its useful to all. |
