3/12/2021 1:54 PM | |
Joined: 8/3/2009 Last visit: 4/23/2025 Posts: 15338 Rating:
Hello adrian Do you use WinCC Comfort/Advanced? I think the problem ist that you use a user- defined Data Type like PLC UDT. Check out the note in the Manual: https://support.industry.siemens.com/cs/de/en/view/109773785/109377913227 Bye Murof |
