10/25/2016 10:38 AM | |
Posts: 1 Rating:
Hi Can you give me clear idea how TIA portal V13 to PLC communication can be done using modbus protocol. Thanks ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 10/26/2016 12:45:41 PMNew subject after splitting |
10/25/2016 11:19 AM | |
Joined: 4/28/2015 Last visit: 2/24/2025 Posts: 10832 Rating:
Hello, sry, very general question show me that probably you're start work with Modbus. Simply I recommend to you start with some helps, documentation. Modbus simply differ also with transfer media/protocol. Also important info is what PLC HW you want use. This info I missing from your post. Start on Modbus.org or www.simplymodbus.ca Then you can look to TIA portal and select due your HW needed instructions. Good luck. |
With best regards... |
10/25/2016 11:30 AM | |
Joined: 2/27/2014 Last visit: 2/18/2025 Posts: 689 Rating:
Hello, See the attached doc file about Modbus Protocol in SIMATIC PLC environment. If you feel this post is useful then don't forget to rate it AttachmentModbus.docx (210 Downloads) |
With Best Regards, |
