10/9/2018 6:55 PM | |
Posts: 1 Rating:
I'm searching the solution too |
10/10/2018 8:28 AM | |
Joined: 4/24/2006 Last visit: 4/18/2025 Posts: 8956 Rating:
Hello, Perhaps this link might help: Remote Access to SIMATIC HMI Control Panels Best regards, Wizard |
10/10/2018 8:34 AM | |
Hello to all you can stop searching there are a lot of information that siemens build up to you : https://support.industry.siemens.com/cs/de/en/view/109476153 Bye Murof -> Edit 8:35AM: Wizard was faster while I was typing.. Timing is everything! |
Last edited by: Murof at: 10/10/2018 8:35:48 AMIf this Information really helps, you could use the Rate function |
10/10/2018 11:07 AM | |
Hello, When you use WinCC TIA Portal v13, you need a Sm@rtServer license on the panel. Do you have one? Then transfer it to panel. When you use WinCC TIA Portal v14 or higher, you can use Sm@rtServer on a Comfort panel without a license. Best regards, Wizard |
10/10/2018 11:08 AM | |
Joined: 7/5/2013 Last visit: 4/17/2025 Posts: 3147 Rating:
Hello Med_selmi,
you need a license for Runtime Version < 14. See SIMATIC WinCC Sm@rtServer (TIA Portal). Regards, Frink |
Pi is exactly three! |
10/10/2018 12:00 PM | |
Hello, Because you want to use Sm@rtServer, I would advise to change Device to v14 Best regards, Wizard |
