7/25/2019 5:26 AM | |
Posts: 12 Rating:
Hi Team, I am having similar issue (r2 [45]), issue could be resolved when I acknowledge it through TIA Portal or from AOP. I want my PLC to acknowledge internally. I send 16#4FE (Fault Ack. Bit) to control word register. but it doesn't acknowledge the fault. Is there any other way I can acknowledge internally ?? Please help, Thanks, ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 07/25/2019 09:12:55New subject after splitting |
7/25/2019 5:56 AM | |
Joined: 5/12/2006 Last visit: 7/7/2022 Posts: 20641 Rating:
hello, which fault you have? Christoph |
7/25/2019 6:59 AM | |
Posts: 12 Rating:
Hi In r2 = [45] Switching on inhibited - remove fault cause, acknowledge fault I am not able to acknowledge this from PLC by using 4FE. Thanks |
