5/20/2014 4:58 AM | |
Posts: 20 Rating:
I have a cpu 315 - 2DP but i can't find it in lib ? how to add CPU 315 in TIA portal v11 |
5/20/2014 5:05 AM | |
Joined: 1/28/2009 Last visit: 11/18/2023 Posts: 6822 Rating:
Which devices and modules are supported by STEP 7 Professional and WinCC Professional in the TIA Portal? Please, also share the ordernumber to see when was the exact release date to tell you more! |
5/20/2014 6:13 AM | |
For sure TIA Portal V11 supports S7-315-2DP CPUs as shown in the attachment.But ,as far as I know, the exact order number ,firmware version and release date are crucial parameters that should be considered while configuring/programming a CPU with a given software.
The older versions may not be supported but for newer , HSP update package(of the given TIA Portal V11/12) should be checked.This is why people still prefer to use STEP 7! |
5/20/2014 6:34 AM | |
Posts: 20 Rating:
Yes, my cpu is 315 - 2AF03 - 0AB0 v1.1 (oldest) |
5/18/2015 3:30 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4785 Rating:
10/15/2015 10:23 AM | |
New question published by mr.adi is split to a separate thread with the subject Change CPU to the same one. Best regards |
