10/27/2017 10:06 AM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello mskrpan1 you only can use SmartTag Array in one dimension. You cannot use a more-dimenstional Array. (only with Script internal Tags) To get access to an array Tag look here: https://support.industry.siemens.com/cs/ww/en/view/26165877 Look at chapter 2 you should also use just Smarttags("Tagename") without the use of the base Object. It would be great if you tell us if you use WInCC Comfort/Advanced or WinCC Profesisonal RT Bye Murof |
Last edited by: Murof at: 10/27/2017 10:08:27 AMIf this Information really helps, you could use the Rate function |
10/27/2017 10:13 AM | |
Joined: 5/20/2014 Last visit: 9/26/2022 Posts: 57 Rating:
Hi mskrpan1, Open you Tag list and VB script in split screen and the just do 'drag & drop'. Tia will do the rest for you. It will have the following format: SmartTags("Elements.Element1.") http://tiaportalhowto.com/en/wp-content/uploads/sites/2/2017/09/TIA-Portal-how-to-insert-tags.gif
tiaportalhowto.com -> TIA Portal Tips, Tutorials, Videos, and more... |
