4/8/2009 10:05 PM | |
Posts: 2661 Rating: (279)
Do you mean extension (which is also a block parameter) like for example .U in MEAS_MON? I have used .ext in the Trigger name for trigger type Tag and it works. Make sure .ext exists in the block structure. See attachment. AttachmentTagTrigger.pdf (385 Downloads) |
4/9/2009 6:59 AM | |
Posts: 325 Rating: (14) |
Dear Phantom, Thanx a ton... Problem solved. Earlier I specified the tag name as ".ext" instead of .ext This made the difference. Gud day. Cheers Nil |
