9/27/2013 1:45 PM | |
Posts: 63 Rating:
Hello Marcjan, Thank you for your reply. The partnumber of the analog module is 6S7_SM331_7KF02-0AB0. Regards, Remo |
9/27/2013 2:19 PM | |
Joined: 4/22/2010 Last visit: 12/15/2022 Posts: 5697 Rating:
Hello, I read you have selected 4DMU(4 wire), for 2 wire connection that should be 2DMU. Then you can use the resitor to bridge unused inputs. If you have selected 4DMU (4 wire) you need to wire the unused chanels in series with the used channel. You can read it all in attached part of the manual. Regards, Marcjan Attachments7300_module_7KF02.pdf (407 Downloads) |
Problem solved? |
