7/26/2006 2:37 PM | |
Joined: 9/27/2005 Last visit: 11/27/2007 Posts: 1398 Rating:
Where did you get the ElConnectorCtrl from ? I cannot find it on my machine. It sounds like this is an ActiveX Control that is part of SICAM PASCC. If this is true then I cannot help as it is not WinCC. In this case, you can either : a) experiment ! Set the properties manually and try and see what does what OR b) contact the hotline using the Support Requestlink who may have more info. |
7/26/2006 2:59 PM | |
Posts: 62 Rating:
Yes, You are right. That is part of Project Library->Topology->PAS CC v5.x. OK, im gonna try link You gave me. Thank You, again! |
7/27/2006 9:18 AM | |
Posts: 62 Rating:
I will answer myself [:)], maybe it will be helpfull someone. Documentation for Topology elements of PAS CC can be found in chapter 5.6 of the PAS CC manual. |
