9/5/2019 1:54 PM | |
Joined: 8/24/2010 Last visit: 7/11/2023 Posts: 23 Rating:
Hello Siwarexi, [snip] Do you know also how to calculate the accuracy of the siwarex card WP321? I found this : d(min(ND))= Delta u min x Emax x N / C / Uexc C is mV/V of the loadcell I guess... What do you think about this calculation? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 09/06/2019 09:06:45New subject after splitting. Division of questions into seperate topics. |
9/12/2019 11:35 AM | |
Hi Siwarexi, Thanks for you answer ;-) Herewith the can find the datasheet of the loadcell : http://www.weightech.com.br/datasheet/hbm-z6fc3-datasheet-b1010-v3.pdf Model -> Z6FC3 with nominal load of 50kg. The scale can be use until 60kg (written on the scale) There is only one loadcell. Let me know if you need something else ;-) Monkeyjacob |
1/7/2021 5:54 PM | |
Joined: 1/4/2007 Last visit: 9/28/2023 Posts: 1061 Rating:
Hello subin, To calculate the accuracy, I need the technical data sheet of the load cell. Best regards Siwarexi
