5/1/2018 4:50 AM | |
Posts: 6 Rating:
hello, acutalmente I am working with this module, only that at the time of setting the DB in dr3 does not allow me to perform the proper calibration, I am using an example of siemens and if you read the module but it is not correct, you can help me saying how to calibrate the module ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 5/2/2018 11:36:51 AMNew subject after splitting |
5/5/2018 6:43 AM | |
Posts: 6 Rating:
Hi, thanks , my module is working. Can help me to know how I can save the weight with a clock signal ?? Thanks again |
Posts: 6 Rating:
Hi, thanks , my module is working. [snip] |
Last edited by: Jen_Moderator at: 5/7/2018 10:48:04 AMDivision of questions into separate topics. |
5/7/2018 10:46 AM | |
Joined: 6/19/2017 Last visit: 9/22/2023 Posts: 7305 Rating:
New question published by ingenia_clm is split to a separate thread with the subject How can save the weight with a clock signal?. Best regards |
