7/31/2014 3:18 PM | |
Joined: 9/27/2006 Last visit: 10/3/2023 Posts: 12153 Rating:
Hello yaloo; You have used the HWConfig parametrization window for your AO channelto set the output to 4-20 mA. But have you wired the output channel for current outputs? Have a look at this extract form the following manual (which you should consult anytime you are dealing with S7-300/ET 200M IO modules): SIMATIC S7-300 S7-300 Module data Hope this helps, Daniel Chartier |
8/7/2014 11:51 AM | |
Posts: 29 Rating:
Thanks for your reply. After changing wiring need to download hardwire configuration?? |
8/14/2014 7:10 AM | |
Posts: 29 Rating:
Thanks For reply. |
2/24/2016 12:52 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4792 Rating:
New question published by raymond.devro is split to a separate thread with the subject AO problem with output. Best regards |
