1/17/2023 12:32 PM | |
Joined: 8/3/2009 Last visit: 4/28/2025 Posts: 15368 Rating:
Hello fabioga66 does it work? i could also be that the generated Runtime Files have some link to the local SQL Server of the old engineering Station. -> In this case reset the IM folder to clear this: https://support.industry.siemens.com/cs/de/en/view/109778709 Bye Murof |
Last edited by: Murof at: 01/17/2023 12:34:01If this Information really helps, you could use the Rate function |
