11/9/2016 10:24 AM | |
Posts: 2 Rating:
HOW TO CHANGE OP7 PROGRAMM WHICH SOFTWARE WE CAN USE PRO TOOL IS GETTING ERROR MESSAGE PREVIOUS VERSIONS NOT FOUND ------------------------------------------------------------------------------------------ |
Last edited by: The Helping Hand at: 11/9/2016 10:30:24 AMNew subject after splitting |
11/9/2016 10:31 AM | |
Joined: 8/21/2014 Last visit: 3/24/2023 Posts: 698 Rating:
Please don't use caps lock and shout. Thanks and regards The Helping Hand
11/15/2016 10:51 AM | |
Joined: 5/28/2008 Last visit: 3/30/2023 Posts: 4399 Rating:
Hello Both, The Configuration software of OP7 is Protool Pro. This software have Versions 6.0, 6.1, 6.2 and 6.3 (if I remember well). You should not use older version than the original version used for your application software. I hope you have the configuration file not just an uploaded image (Prosave Image) You don't need to have protool to make migration ! Just open it using (WinCC flexible 2008-SP2)---- "Don't use WinCC 2008 SP3 Then you can make another migration using WinCC comfort. If you have any difficulites, please tell us here again. Hope this helps. |
Ayman Elotaify |
