3/29/2020 4:24 PM | |
Posts: 7 Rating:
Hi solved my problem, thak you for the awnsers. i know this was allredy askd, foud the explanatons, but it didnt manegd to make it work. how do i change screens via tia portal using tags? thank you for the awnser ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 03/30/2020 11:03:45New subject after splitting |
3/29/2020 5:02 PM | |
Joined: 9/27/2006 Last visit: 4/17/2025 Posts: 12346 Rating:
Hello Beginner; If you want to learn how to program your PLC and HMI with any confidence, you will have to take Hati's suggestions on search resources here seriously. For example, a 2-second search on the forum brought me this answer: https://support.industry.siemens.com/cs/ww/en/view/93909293 Hope this helps, Daniel Chartier |
4/9/2020 10:10 AM | |
Hello BeginerJng and of course you should work on your spelling. A mistake now and then is OK... but in almost every word... have a nice easter weekend Bye Murof |
