3/5/2012 9:53 AM | |
Posts: 17 Rating:
Hello Raghu, I set up the configuration between a 300 and a 1200 using the GET and PUT instructions. You have to configure an S7 connection between them and then it should work. You can also check this link for more info. best regards |
3/6/2012 5:52 AM | |
Posts: 65 Rating:
Hi, Thank you so much for your reply. I will inform you once i am done. Regards, Raghu |
