3/5/2012 6:32 PM | |
Joined: 9/24/2010 Last visit: 11/14/2022 Posts: 118 Rating:
Following member bakerjw give S7-1200 Profibus example with MM440 motor drive at: /tf/WW/en/Posts/57694#topI'm not yet read because 1AM at my country. I will check it on next day. Thank you bakerjw so much. I will reply soon and give my result. Thank you a gain |
Mechatronic Center |
3/6/2012 6:48 AM | |
Joined: 8/31/2010 Last visit: 2/3/2023 Posts: 1498 Rating:
Check this application example on Connecting a SINAMICS drive to an S7-1200 CPU in TIA Portal (via GSD file)- Instead of SINAMICS Drive you are going to use MM420 PROFIBUS DP Drive. |
Like it? Rate it! |
