9/22/2023 10:02 AM | |
Posts: 1 Rating:
Hello, Tell me if you managed to solve this problem ? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 09/25/2023 05:55:56New subject after splitting |
9/28/2023 11:23 AM | |
Joined: 8/3/2009 Last visit: 4/29/2025 Posts: 15379 Rating:
Hello Sick0001 Events in Faceplate interfaces are supported since TIA Portal V18 In the manual you will find description and an example: https://support.industry.siemens.com/cs/ww/en/view/109813308/160903526283 It works slightly different to WinCC comfort/advanced. in WinCC Unified it works with scripts Bye Murof |
Last edited by: Murof at: 09/28/2023 11:23:43If this Information really helps, you could use the Rate function |
