5/23/2012 2:11 PM | |
Posts: 691 Rating:
You need to manipulate the Analog signals and generate High/Low Bits through Comaprison in the Program. You will get so many tips in the Forum . Just Search 1 , 2 , 3 |
5/24/2012 1:03 PM | |
Joined: 5/17/2010 Last visit: 2/21/2022 Posts: 80 Rating:
As manmeet says you can use FC105, but this block only use the ENG value with REAL data type. The input value will use fixed value from 0 to 27648 for minimum and maximum input value. I just saw the links from Niranjan. Never tried but looks good |
