4/9/2010 2:50 AM | |
Joined: 10/7/2005 Last visit: 12/12/2024 Posts: 3029 Rating: (1057)
Hello iyerm2 probably not, I doubt that the CP535 supports ITP (its an ancient Ethernet CP and I don't even have its manual). An AUI to UTP transceiver is the save bet here (and probably even cheaper than the Siemens cable)and if you want to know for sure I suggest you contact Siemens Service & Support or get your local Siemens rep to find out more. Note that the IE TP Cord RJ45/15cord is however all you would needfor aCP1430 TF which does support AUI and ITP (see also THIS thread). I hope this helps |
Cheers |
