12/10/2015 6:26 AM | |
Joined: 5/12/2006 Last visit: 2/15/2025 Posts: 22539 Rating:
Hello, here you can find a application example for thic configuration: https://support.industry.siemens.com/cs/ww/en/view/70155469 If you have any questions or problems with the example please ask. Regards Christoph |
12/10/2015 6:55 AM | |
Posts: 5225 Rating:
Christoph, are there any specific requirements |
12/10/2015 6:23 PM | |
Joined: 9/16/2014 Last visit: 1/11/2025 Posts: 30 Rating:
Helo the_learner99, You must consider that the name of both, PLC and G120, has to be written in lowercase letter, Because if you type those in capital letter you won't achieve the profinet comunication. Check the manual to see what telegram you will use: https://support.industry.siemens.com/cs/document/109478828/sinamics-g120-converters-with-cu240b-2-and-cu240e-2-control-units?dti=0&lc=en-US Regards |
12/10/2015 6:45 PM | |
Hello, this is not correct. you can configure the name with lowercase and uppercase, in the device the name is stored in lowercase that's correct but in the engineering you can use both letters! Regards Christoph |
