10/9/2023 8:43 AM | |
Joined: 9/18/2006 Last visit: 11/14/2024 Posts: 593 Rating: (64) |
Hello Max. I will need to work with the Siwarex 321 module in 1 week. I have not yet found how to connect this module to the application via RS-485. Maybe you can tell me which pins of the module and what to connect to. I will repeat your question: has anyone had any success in using a standard USB to RS485 converter to communicate to the WP321? If so, would you know what the port setting are (Parity, baud and the like)? I am trying to use a generic converter with no luck. Thank you. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 10/09/2023 12:37:59New subject after splitting |
10/9/2023 8:50 AM | |
I may have found it. |
