2/27/2013 9:09 AM | |
Joined: 4/22/2010 Last visit: 12/15/2022 Posts: 5697 Rating:
Hello, Have a look at attached pdf. Hope your signal is below 300Hz. Regards, Marcjan Attachmentphoenix.pdf (751 Downloads) |
Problem solved? |
3/5/2013 12:12 AM | |
Joined: 2/15/2009 Last visit: 2/5/2023 Posts: 12 Rating:
try this, should work at least up to 1MHz...
Attachment24V-TTL_converter.pdf (951 Downloads) |
3/5/2013 1:56 PM | |
Posts: 28 Rating:
If i understood you correct, i think when you connect 1.5 kOhm resistor asserial connectionso you can solve your problem. |
