3/18/2014 8:01 AM | |
Posts: 4 Rating:
Here are the files I have for what appears to be the latest version of the program. All the versions have the same number of files with the same extensions. I hope you can make something of this. - Thanks Attachmentthetbrd.zip (197 Downloads) |
3/18/2014 8:52 AM | |
Joined: 4/24/2006 Last visit: 2/1/2023 Posts: 8586 Rating:
Hello stephen, Can you give the order number of the used CPU? Perhaps you need Step 7 Micro/Win Use the following link: Project cannot be opened Best regards, Wizard |
3/18/2014 11:12 AM | |
Joined: 4/22/2010 Last visit: 12/15/2022 Posts: 5697 Rating:
Hello, To comlete the story: 1. You need Step7 Microwin 2.1 to open the file. 2. Deselect Symbolic addressing. 3. Switch to STL view. 4. Save the program. You can now open the File in Microwin V4 (select PRJ as filetype) After opening you can switch to Lad view again. See attachment. Regards, Marcjan Attachmentconverted.zip (184 Downloads) |
Last edited by: Marcjan at: 3/18/2014 11:24 AMLast edited by: Marcjan at: 3/18/2014 11:13 AMProblem solved? |
