1/16/2007 1:57 PM | |
Posts: 218 Rating:
Hey, So you want counters that count over 65k, but not over 2,147,483,647. Attached you should find a FC that counts over 65k. This will give you an idea of how it can be done. Where as I have used MD in the example you should use DD's. Hopes this helps. Jeebs AttachmentCounter.zip (334 Downloads) |
