3/20/2009 11:40 AM | |
Joined: 5/28/2008 Last visit: 12/8/2015 Posts: 901 Rating:
Hello, what Software do you use? regards Manfred |
3/20/2009 11:48 AM | |
Posts: 8 Rating:
WinCC v6.2 SP2 |
3/20/2009 11:55 AM | |
I not realy understand your problem... please could you explain more details...?!?!?! regards manfred |
3/23/2009 10:32 AM | |
Hi sinau For your own standard objects, i advice you to create a new picture as your library. Then you can copy your standard objects in the picture, you needed it. at the property "Event">"Mouseclick" can you add vbs scripts. to change the color of the same object, you call the script, you do not need to create an object. You can change the property of the object (item) direct in that way: Item.Top = 100 Item.Left = 250 Item.BackColor = RGB(250,0,0) 'for the red color I hope i understood you right and i could help you regards cumulus |
Learn more about visualization - visit the HMI courses of Siemens AG! |
