11/29/2010 2:24 AM | |
Joined: 10/7/2005 Last visit: 2/2/2023 Posts: 2954 Rating:
Hello zouki STL is(for unknown reasons as far as I'm concerned) notpossiblein TIA Portal V10.5 or current S7 1200's so you can't directly take over you logic (it appears though thatimminentrelease ofV11 will bringSTL to at least the 300's and 400's but perhaps also 1200's). You also quite rightly determined that XOR is onlyavailable for Byte/Word or DWord types ifLadderis used (the same applies for the "normal' Step 7 too by the way). While you could manually program a Ladder bit based XOR, the good news isthat you have a bit XOR element available in FBD which should help implementing your toggle logic in the 1200. Attached is an example screendump of it and I hope this helps. |
Cheers |
10/13/2017 1:40 PM | |
Joined: 9/1/2005 Last visit: 1/9/2023 Posts: 4097 Rating:
Hello zapla1,
Please keep me informed what you have tried to do. You could share this information public or contact me via personal message. Best regards |
