8/16/2011 2:08 PM | |
Joined: 6/29/2010 Last visit: 10/27/2022 Posts: 112 Rating:
Hello friends, Take a look at print screens that shows how to create a UDF in LOGO! Soft Comfort 7.0 Regards, AttachmentCreate UDF.zip (1356 Downloads) |
Last edited by: MrPaiva at: 8/17/2011 5:55 PMLast edited by: MrPaiva at: 8/17/2011 5:54 PMLast edited by: MrPaiva at: 8/16/2011 2:10 PM |
4 thankful Users |
8/16/2011 2:50 PM | |
Posts: 495 Rating:
Nice Work MrPaiva! There isa secondway to create a UDF. See attached pictures. After picture 2 follow the steps 3 to 7 from MrPaiva. Regards, AttachmentCreate_UDF_V2.zip (804 Downloads) |
4 thankful Users |
10/13/2011 5:01 PM | |
Posts: 6 Rating:
Hi everyone, I was testing the UDF example and I realized that if you create an UDF block with aAND function, for example, and you connect 4 inputs at the first time, you are obliged to use all 4 inputs when you call the block inanother project. If you use less, the logic does not work. Regards, Lais AttachmentUDF.pdf (571 Downloads) |
Last edited by: Lais Sono at: 10/13/2011 5:28 PMLast edited by: Lais Sono at: 10/13/2011 5:15 PM |
4/18/2014 8:25 PM | |
Joined: 4/22/2010 Last visit: 12/15/2022 Posts: 5697 Rating:
Hello, After saving the UDF, goto Options, Click on UDF and then ADD your udf, you can now find it in your blocks tree. Regards, Marcjan Attachmentudf.pdf (486 Downloads) |
1/16/2018 3:44 PM | |
Joined: 6/19/2017 Last visit: 12/7/2023 Posts: 7572 Rating:
New question published by CHolder is split to a separate thread with the subject Created a UDF but it is Greyed out when try to use it in the Circuit Diagram . Best regards |
