4/22/2022 9:18 AM | |
Hello Max_Sns It depends a little bit if your Runtime runs on a Panel (Comfort Panel for example) or on a PC Based Runtime System? For Panels with WinCe you only have the folowing Methods for File Access: https://support.industry.siemens.com/cs/de/en/view/109773785/101387121035 So here the suggestion of Prof will be the best i think Bye Murof |
