11/23/2011 11:40 AM | |
Posts: 3037 Rating:
Hello, |
11/23/2011 11:49 AM | |
Posts: 3 Rating:
Can you give me an example, because i'm not usefull with Script! |
11/23/2011 3:34 PM | |
Posts: 3037 Rating:
Hello, You can see in the following FAQ the functions of script of WinCE. Differences between the VB script functions of Windows and WinCE Here is an VBs example: Dim fs, path Set fs = CreateObject("FileCtl.FileSystem")path= "Storage Card MMC" If fs.Dir("\" & path) = "" Then 'Card not available ElseIF fs.Dir("\" & path) =path Then ' Card available End if Set fs = Nothing |
11/23/2011 5:57 PM | |
Posts: 3 Rating:
Thank's a lot. That work's exactly as i would like. |
1/19/2012 2:02 PM | |
Posts: 3037 Rating:
Hello, This script runs only of a Panel with WinCE. You must use this for computer with Windows. CreateObject("Scripting.FileSystemObject") Tweety |
1/29/2014 1:01 PM | |
Joined: 9/1/2005 Last visit: 1/9/2023 Posts: 4097 Rating:
new question published by pachuis split to a seperate thread with the subject Op177B within memory card - It says unsupported storage card detected Best regards CS Moderator |
