1/31/2017 6:04 AM | |
Joined: 10/17/2007 Last visit: 3/19/2023 Posts: 3276 Rating:
You are really new for this filed --if this Q's is same as your topic simodrive 611 alarm 300501then the simple answer will be system will do it automatically. you know the sequence--as you already did it.--the more important is the angular different cannot be too larger --I mean encoder zero and electrical zero different must in limited --such as 11 degrees then run sequence. it will automatic correcting
Please Help me to understand your question! |
