1/28/2016 5:30 AM | |
Joined: 2/12/2014 Last visit: 5/28/2023 Posts: 158 Rating:
#i use passive sensor on 4 AI8 module (32 channel) |
1/28/2016 9:50 AM | |
Joined: 9/16/2013 Last visit: 9/14/2023 Posts: 199 Rating:
As I told you yesterday: Use the TIA selection Tool or calculate your losses with the datasheet and formula P=V*I: http://lmgtfy.com/?q=6ES7+331-7KF02-0AB0+datasheet
If you cant calculate it, use the 10A power supply, it will be a lot cheaper when you take the oversized power supply instead of calculating for hours and take the proper power supply
