8/26/2022 12:51 PM | |
Hello modula the protocol is mostly used for access to network share. Here you can also use OPTION+ instead then you have a higher security and do not need SMB1 https://support.industry.siemens.com/cs/ww/en/view/92346478 Bye Murof |
