6/17/2021 11:03 AM | |
Joined: 2/17/2016 Last visit: 5/16/2022 Posts: 1 Rating:
This requires a module firmware version newer than 3.0. There is no such option in module firmware version 2.X. You should also take into account that 3.X software versions require the corresponding hardware product version: 7 (zb for 6GK7 343-1CX10-0XE0). Whereas versions 2.X can be installed on hardware product version 5. Thus, it is not always possible to update communication modules to the latest software version (3.X) due to limitations on the hardware version. In my case, it turned out to be updated only to firmware version 2.48. From a security point of view, a check mark for disabling the web server has appeared in the module settings.You cannot disable snmp in this version in this way. Attachmenthy_S7-CPs-IE_76.pdf (659 Downloads) |
Last edited by: dimka at: 06/17/2021 11:10:43Last edited by: dimka at: 06/17/2021 11:11:36 |
