6/8/2015 1:05 PM | |
Joined: 8/3/2009 Last visit: 1/24/2025 Posts: 14651 Rating: (1825) |
Hello RKM You can use since TIA Portal V13 the Proxy PLC to use ALARM S between Classic and TIA, look at this: https://support.industry.siemens.com/cs/ww/en/view/73502293 But you cannot use Basic Panels for Alarm_S. Its not supported. With Comfort Panels it should work. Hope it helps Bye Murof |
