2/3/2014 5:31 AM | |
Posts: 515 Rating:
hellomehtabahmed, Inorder for this, i would suggest you to create your own timer block by using an ADD Block and clock pulse bit, so that it will be easy for you to display the time elapsed. Since S7 timers are not retentive, we use own made timer blocks which can be easily displayed. This is my suggestion, or if you want to display the S7 timers value, some experts may well help you.
