7/3/2013 8:00 PM | |
Posts: 2964 Rating:
Hi, Seen long back bu with some different type... With the help of HMI customize screen....You can give try using winccflexible-Visual bascis Regards, Prakash |
7/4/2013 3:57 PM | |
Posts: 391 Rating:
Hello, you cannot modify the standard machine screen to add the gear stage in the spindle window. If your machines have HMI-Advanced, maybe the easiest solution is to customize the header of HMI-Advanced. You can add your own icons, for example you can prepare an icon for every gear stage and link them to some bits in the PLC. more info here: https://www.automation.siemens.com/doconweb/pdf/SINUMERIK_SINAMICS_02_2012_E/IHA.pdf?p=125#page=125&view=FitBH,0&pagemode=none please read the full chapter. |
