12/13/2021 10:14 AM | |
Joined: 6/22/2017 Last visit: 2/1/2023 Posts: 339 Rating:
Hi, i highly recommend you this document: https://support.industry.siemens.com/cs/ww/en/view/109758536 First, just to be sure, i would compare your TagValue1 with "true" or "false". Then you need to search your ScreenItems first. This is described in the document, how to do it. Then your code should work. Best regards |
